JTBME
JTBME
- JTBME
- 40
Hi, just wanted to let you know that the "noise" had to do with the # of channels and whether or not the daisy board was connected. Whenever I used 8 channels on the gui but had the daisy connected, the raw data had that 125 hz spike on the fft plot…
Yes, I think the wires were the problem. It's working fine now! Thank you so much for your help (it is greatly appreciated), JT
I am seeing the same issue in the GUI. Channel 7 was turned off, but the raw data txt file still includes it and its high amplitude and similar noise to the rest of the channels made me wonder if it was a part of the problem. Could be something in t…
Thank you for the quick response! I'll try that
