JLG
JLG
- JLG
- 77
Thank you for your quick reply. I had no clue about the galvanic battery effect. Thank you for the reference. This is not so much the picked up noise that is my issue but the channel-to-channel discrepancy. Noise does not discriminate, it should b…
Additionnally, I have considered that human differ widely in terms of alpha waves generation but I have no problem seeing alpha waves when I use every channel from 2 to 8, the only one who causes troubles is the channel 1. I locate the electrode on …
I wanted to limit the amount of pictures in one message but for the second test what I wanted to see was to further investigate some potential issues regarding electrodes and the way the board handles my electrodes. What I did is the following: I …
Hi Philip and William, Thank you very much for the quick reply. I was using the OpenBCI GUI 5.1.0 on Windows 10. I would like to clarify my observations: I had three resistors 1MOhms, 680kOhms, 470kOhms. When looking at Chip's blog (https://…
@wjcroft said: Regarding the raw data, this is unfiltered. The ADS1299 needs to have the DC offset removed, typically with a bandpass (.5 Hz to 45 Hz) or a highpass at .5 Hz. Without filtering this you will see this DC offset, frequently in the m…
Hi both, I actually have the same issue. When I connect fixed resistors (by opposition to a potentiometer) with values around 1MOhms then I get correct results in the GUI (around 980 kOhms) but if I decrease the value of my resistors, the value set…
Hi again, I contacted the support last friday and I am waiting for their answer but in the meantime, I wanted to know if you had any idea why this uploading issue happened. I tried with a new computer, it worked 3 times then same issue with the cor…
Ok thank you, will try it on another setup. Kind regards
No I checked this part, the port COM 4 was still there unchanged. The baud rate was 9600 which is the correct baud rate for the upload of the firmware, right?
I thought about the same as the full error message was: \.\ COM 4 Cannot Open No target found So I thought about the port already being used or renamed so I rebooted the computer and nothing changed. I don't know yet how to OS scan my COM port bu…
Dear WjCroft, thank you very much for your input. This solved the issue. I proceeded as discussed and found in the firmware the debugging mode that you described. I then used the example BoardNoAccelSDWifiDebug to play a bit around and the proceeded…
Hi again, I now think that I have less vague questions: * Usually PIC32 has reprogrammable digital pins that can be used for UART serial communication. From the PIC32 datasheets, it appears that a lot of the pins can be reconfigured to be used …
Thank you for the reminder and you are 100% right. We are still in development phase of the project and are still determining what can be achieved using the OpenBCI hardware in our specific application and how/if we can manage to do it. Will defini…
Thank you for the quick reply and the useful links. Do you know if it is also possible to use the UART protocol to stream directly the data to a Raspberry without having to use the dongle? I imagine it would be using the digital output pins that I …
