JDavid
JDavid
- JDavid
- Portugal
- 20
- Portugal
In my case, I have 4 frequencies. One question, the bandpass filter only does a limition fo the signal bandwdith, right? How can I extract a SSVEP with a bandpass filter?
I am using a notch filter and then a bandpass filter to limit my frequency bandwidth, and I apply certains methods. The features extraction (amplitude of the signal) is then obtained by a FFT method or Welch or CCA method.
Hello, thanks for the reply.Yes, I am using. But when I process the output of stream, wouldn't I be losing some realtime samples ? Regards,
@compujohnny How do you upload the firmware to the cyton board if it wasn't giving a blue led and it wasn't working? I am having the same problem
