Haseeb
Haseeb
- Haseeb
- Lahore
- 164
- Lahore
Connect PIC rx pin to ftdi tx pin and vice versa. Everything else seems fine to me.
Please double check that you're following the Bluetooth based firmware uploading guide with only difference of direct rx/tx pin connections of ftdi with pic controller's tx/rx pins and the ground pin obviously.
Thanks @wjcroft and @retiutut. I have created a post in community forum regarding this demo.
I was able to make this project with the help of my team using cyton board and wifi shield: Thanks to OpenBCI. Regards Haseeb
Congratulations @alwayswearshats! Keep it up.
Yes, it is possible over wifi. When I started the gui through processing, I was able to see the commands in console that were sent over wifi for channel settings. The SDK commands can be sent through bluetooth or wifi. See the SRB1_Test on the link …
There was a problem with my spi pins of wifi module. It is working now. I want to summarize this thread that you can run cyton board with wifi shield without using bluetooth dongle or bluetooth module on the cyton board. You just need one time…
I checked OpenBCI_32bit_Library and found that it prints addresses of ads1299 and LIS3DH after communicating with them using SPI.
Hi William! I checked the OpenBCI_GUI code, it either connects through WIFI or bluetooth not both at a time. I checked the swagger hub that shows meanings of different response codes of WIFI shield. The OpenBCI_GUI on startup reads those codes t…
Hi wjcroft! Thanks again. I uploaded the bootloader using pickit 3 and was able to upload the firmware without using bluetooth, by directly connecting the Rx and Tx pins. Now I am using the wifi shield. I have got an issue. The OpenBCI_GUI detec…
[Original thread title: Standards and benchmarks followed in designing Cyton board] What are the international standards you followed while designing Cyton board?
Thanks ahsanic
Thanks wjcroft
Hi ahsanicCan you guide me about burning code in pic32 using pickit3?
Got it. Thanks
Thank you William, I'll look into the cyton schematic. Do I need the serial connections after uploading the firmware as you mentioned the way OpenBCI_GUI interacts with cyton? What I was thinking is to upload the firmware using wired connections th…
Alright! Is it the bootloader that allows to communicate with the chipkit serially? I'll go for the FTDI device option. What will be the connections? I mean where to connect the Rx and Tx pins of FTDI device on cyton board?
It is fine with me to use Pickit 3 but I have a confusion. In the openBCI documentation, it first talks about bootloading the chipkit with Pickit 3 then it talks about uploading the firmware using Bluetooth dongle. Is it possible to upload the firmw…
Thanks William! I read the discussion. I know that break out pins are available for bootloading of chipkit but it couldn't answer my questions.
Sorry! I should have posted in build-it-yourself category and now it seems I don't have the permissions to move it to the build-it-yourself category.
