GrahamCousens
GrahamCousens
- GrahamCousens
- Drew University
- 30
- Drew University
Hi William, Thanks so much for confirming this. Ideally we could run in analog mode and read the voltage values from the z accel channel instead of an analog pin. I don't see where there's a single place in the firmware to do this, though showi…
FYI: An analog thermocouple amplifier (AD8495) worked best for this application, where the highest degree of temporal resolution is required.
Thanks again for your help. I'll let you know how it goes.
That's true. However, this particular application requires temperature (as a proxy for airflow) measurement from different locations within the nasal cavity. This might differ from chest strap output right after swallowing, which is the period we're…
Ok. Thanks William.
I'm going to try the way that involves a lot of work. Is there sample code on reading from and SPI device through the OpenBCI platform?
I noticed that, but the issue is that I need to position it in the nose to measure faint changes in respiration. The thermocouple is a good sensor for this purpose. I really appreciate your comments. Very useful.
I don't want a lot of work. Is there a way to get the temperature readings from the arduino into the data file collected by the Cyton? One possibility might be to use a DAC breakout on the Arduino and feed the voltage signal into an analog channe…
Thanks so much WIlliam. I'm using a Max31855 thermocouple-to-digital converter, which works well on my arduino. I can't quite get it to work on the Cyton board. The converter has the following pins, which I've connected to the Cyton board in thi…
