GiordanaDibbe
GiordanaDibbe
- GiordanaDibbe
- 16
Hi William. Yes, both the devices were correctly working until yesterday morning. I have tried on 4 different PCs, but I still get the same errors. I post you the log file for both the "autoconnect" and "autoscan" mode. AUTOSCAN: Console Log …
@wjcroft said: I see that you are in Italy. A reliable source of sd cards, is generally an electronics distributor that gets shipment directly from the manufacturer. This is not the same as a 'retailer' or online seller, which cannot be trusted. …
Hi everone! I'm having the same problem here, but I'm using a 16GB SDHC class 10 micro sd. When I open the .txt file saved on micro SD, a corrupt file is opened. How can I do? Awaiting replies, thanks in advance.
