GeorgLange
GeorgLange
- GeorgLange
- Potsdam
- 53
- Potsdam
Hi there, I experienced the same issues! Although I had not the time to check the real reason for this, I developed a few techniques that seemed to raise the chance of a successful recording: * Don't delete files on the SD card. Often, it di…
Hi Andrey and William, Thanks for your update!
Thanks for your help, I'll do that.
Hi, Yes the 4 recordings were 8 channel. I tried today on a few other computers with Windows 10 and new Hardware, but following problem occured: After inserting the dongle, Windows recognizes the device and the dongle's blue LED turns on. But after…
I tried 4 recordings today with 5-60 minutes recording time. 2 were successful recorded, from one recording, the last 10 minutes are missing and the 4th recording failed. So it's probably not the Daisy board. Is there any way to get immedately notif…
I have the latest GUI and the OpenBCI was purchasted very recently but it didn't ever work correctly . I tried with 8 instead of 16 electrodes and a 2000s long recording seems to was successful.
I tried with a 16GB SD card now that fullfills the requirements. But unfortunately, I have to confirm that the problems are still there.
Hi William, Thanks for you help. I will try this. The impedance is about 50kOhm. Is this correct? What does it mean if some electrodes record 0.0 (and 0.0Ohm) all the time? How can I fix it? I am using a SanDisk Ultra as suggested. Any other ide…
Hi William, Thank you for your suggestion. Unfortunately we don't want to use an OTG cable as this is not a good user experience and we want to use BLE for all our devices. But anyway, we think that in terms of data volume and battery drain it wou…
