Default Avatar
Galindo
Galindo
Username
Galindo
Location
México
Joined
Visits
14
Last Active
Roles
Member
Location
México
  • RESOLVED. The input for the Cyton was not D13, as indicated in: https://openbci.com/community/measuring-stimulus-timing-with-a-photoresistor/ but D12 as indicated in picture in: https://github.com/OpenBCI/OpenBCI_Experiment Thank you!
  • Thank you William, Did you use the Widget in the GUI to select Analog Board Mode? There are separate controls for Analog and Digital modes. R: Yes, I've done this according to tutorial. I was expecting to see some color or value changes in the cir…
  • Thank you wjcroft, I've changed the photodiode for a photoresistor, as indicated https://github.com/OpenBCI/OpenBCI_Experiment. But I can see no changes in the stream, neither in the output values. Voltmeter indicates 1.4 in light mode, and 1.2 i…
  • I've tested the solutions presented in the examples, but still missing something. I can not see changes in the sensing signal coming from the photodiode, maybe expected if there is not a graphical channel for this during the data stream. But in the …
  • Great, thank you for the fast help. About hardware: As long as I read, in this circuit, there is no need to use an optocoupler? About the software end, Should I download and paste somewhere the files in the indicated link? https://github.com/…
