Avatar
GabeIbagon
GabeIbagon
Username
GabeIbagon
Location
San Diego, California
Joined
Visits
59
Last Active
Roles
Member
Location
Facebook
Gabriel Ibagon
  • @Paski, this sounds like an "unsatisfied link error" (this message should appear in the Processing console). The reason for the error is that you need to point Processing to the new LSLLink library. I don't have exact instructions on hand right now,…
  • Hi Paski - if you can describe your issue in more detail, I may be able to help. Are you simply unable to receive the stream in Matlab (but the GUI continues running fine)? In the meantime, you can view this document about using the Networking Wid…
  • Hi @gubbeen - your understanding of the data flow is correct. You will also be able to send LSL through the GUI while still recording to a file in the GUI, so that shouldn't be a problem. Also note that you can record an LSL stream using LabRecorder…
  • Hi Katherine, That repo is a bit outdated. New documents should be coming in the next few weeks. Instead, try following the instructions on the OpenBCI_LSL repo to set up an LSL stream with OpenBCI (https://github.com/OpenBCI/OpenBCI_LSL). Use…
  • Since Matlab is not returning any errors during LSL startup, I doubt that it is a dependency issue. Still, you might want to double check that you have the correct dependencies anyway. For BCILAB, there should be a folder in your BCILAB directory wi…
  • Hi @Winslow_Strong, I wrote up a tutorial based on your advice! Thanks a lot for the help. Here's the guide: http://docs.openbci.com/software/06-labstreaminglayer
