Default Avatar
EmbSysDev
EmbSysDev
Username
EmbSysDev
Location
Mumbai
Joined
Visits
22
Last Active
Roles
Member
Location
Mumbai
  • _Actual AC must be used to avoid the polarization aspect. _ Could you explain further, please ? I am a bit confused , because there is no negative potential on the Ganglion board. In the Cyton board we have a voltage inverter to get a negative pote…
  • Unrelated to this discussion, I saw this link you had posted . http://www.eeginfo-neurofeedback.fr/fileadmin/images/was_ist_neurofeedback/wie_funktionierts/SCP_recording_electrodes_and_paste.pdf Unfortunately its gone dead. Any chance if you stil…
  • Thanks much for your valuable time and advice. On sheet 2 is shown an output "micro-amp sense" line. I will simulate the circuit using LTSPICE and check and post back. It's not that critical which is used, as long as it is AC. You cannot use DC…
  • Hi William, Thanks for the reply. Ganglion does a similar current injection, generated by the DAC. From what I can see, it sends a voltage and not a constant current from the DAC. Also I think you mentioned in of your older posts that it is a tr…
