ElisabethSmithie
ElisabethSmithie
- ElisabethSmithie
- 98
- @infobookcom
- https://www.facebook.com/elisabethsmithie
Hi @faheermersh! Thank you for your advice! Best wishes Elisabeth
Hi @faheermersh, I am using the Ganglion and I am following your instructions above to transfer the steam to MATLAB, but I am encountering some issues. I am therefore trying to verify that I have a stream in Python using advice by @Gabelbagon. Cou…
Hi all, Hi @GabeIbagon After running the openbci_lsl.py and obtaining the result further down, in order to confirm that the stream is well received in Python, do I run the ReceiveData.py https://github.com/sccn/labstreaminglayer/blob/master/LSL/lib…
Hi @faheemersh! Congratulations on your work (and on solving the issues mentioned on page 1 of this thread)! Thank you for posting the link to your Github repository! I will be studying this content in detail, thanks. Best wishes Elisabeth
Hello William (@wjcroft), Following your advisement, I have posted the issue here: https://github.com/OpenBCI/OpenBCI_GUI/issues/315. Thank you Best wishes Elisabeth
Hello William (@wjcroft), Thank you for your response (including your suggestion for an alternative solution). Best wishes Elisabeth
Hello, On the occasion of the Brain Week I would like to tell my facebook friends etc. to download the OpenBCI GUI and load a file for playback. Is there a file I could use? At this thread further above, Joel @biomurph says in 2015: "If you downl…
Hello William @wjcroft, Thank you for your response! Best wishes Elisabeth
Thank you @gilesforrest for your comment!
Hello @pwilliams, Thank you for your comment. My cell phone was at a distance of 1.5m/5ft in my bag and its status was the same during the whole recording - actually I don't know if it did an app update but it did not for instance play a video. I …
Hello @biomurph,Thank you for your response. My environment consisted of the following electric appliances and elements: 10-inch laptop, 3 halogen lamps on the wall, one small refrigerator and a cable TV-WiFi box. (Electrode 3 would be closest to th…
@paski @wjcroft Thank you for your responses. (I was using the 60Hz notch filter). Best wishes.
@cetlicharp: Okay.
@wjcroft Issue resolved! First installed the driver "CSR Harmony Wireless Software Stack" that came with the CSR4.0 dongle CD, (then restarted PC), then replaced the driver using the Zadig tool and then switched on the GUI, switched off and then bac…
It was possible for the GUI to find the Ganglion BLE on a Windows 7 laptop of mine that I tried. I followed the procedure of the suggested post of the guide and first installed the "CSR Harmony Wireless Software Stack" that came on a CD with the CSR…
Replying to @celticharp Yes. Thank you for your comment.
Replying to @wjcroft Thank you for your response. I have an ACER Aspire SW5-012 (32bits, Windows 10) which has a single USB port, and that is a USB2.0. I have verified that indirectly from the Device Manager (image below), as there is only one …
Hello, the GUI still doesn't find the Ganglion BLE on my computer after I obtained the CSR4 dongle (from local vendor Amazon.fr). As shown at the image the dongle is listed and I have used the Zadig tool to replace the driver. I am afraid …
Thanks for your comment and the screen shots, @pushtheworld.
Thanks for your comment, William @wjcroft.
Hi William, Thank you for your response. Best wishes Elisabeth
