Eduardo
Eduardo
- Eduardo
- 1
For now the code is too specific for my application to be of use for that many, I'll publish everything and share it here once it's complete regardless.
Thank you, I'll check it out, I'll probably implement it later on, for now I'm sending directly the codes I need depending on the context, I'm short on time and can't properly check the code you recommended at the moment. If I get the time to expand…
So far I was able to interface with the BLED112 dongle with the specific document: https://www.silabs.com/documents/public/reference-manuals/Bluetooth_Smart_Software-BLE-1.8-API-RM.pdf#[{"num":429,"gen":0},{"name":"XYZ"},0,712.61,0] Once more than…
Thank you, I'll check the resources you linked, I'll add another answer later with my results
