Dreaming_Geek
Dreaming_Geek
- Dreaming_Geek
- Atlanta
- 40
- Atlanta
Also, I am getting some wonkiness when I connect BIAS to an electrode on the top of my head.
Thanks.Connected the other ear to the daisy, and now have all channels.
Feel free to borrow my image.Though someone should do a better job of coloring it. "Is 'R' meant to refer to 'Reference'? Generally the Reference is going to one or both ear lobes. And the Bias can go to any of the unused 10-20 or 10-10 sites." …
I combined the info from a couple of docs found here and did a quickie coloring in photoshop to keep my wires right.This seems to match the placement in the GUI.
Oh, I thought I was supposed to connect one ear to SRB1 and the other to BIAS on the mainboard.This is wrong? Yes, the daisy board has always railed. I thought it was the crappy headset I had before. But, now I wonder.
Are there other details I should give?
Thanks for the tips !
Is there any mapping in OpenVibe?
Thanks.Just got the gear and am fumbling forward.
Thanks.Guess I am just having a hard time getting my head around there not being a set standard. I wonder if BrainBay's mapping differs from the OpenBCI GUI?
wjcroft- You said, 'You can connect any channel to any 10-20 site, it's your choice.' Last time I tried connecting 8 leads, they didn't correspond to the default mapping in the OpenBCI GUI. So, clearly I have no idea what pins correspond to what p…
Thanks for letting me know where the thread went.Guess I just wasn't using the right search terms to find those threads. Awesome to know that it already exists.
Housing boards and batteries - fan possible? Because I live in proximity with small children, I would really like to get my gear in some sort of housing.I had thought of converting a little box that is about 5x5x2 inches. I've often been wondering…
Now you have me intrigued with source localization.I did find something on github, but that sort of package makes my ears bleed. https://github.com/kuz/BrainActivity3D I was trying for something like that recently. I tried making a 3D brain at…
Perhaps I need this kit then? http://fri-fl-shop.com/product/package-of-50-disposable-reusable-dry-electrodes-and-25-eeg-wet-cup-electrodes-and-20-leads-red-white-green-black-grey-brown-blue-purple-orange-yellow-tracers/
Thanks for your prompt answer.Obviously, I have a lot to learn. Other than your suggestions above, the wires can be connected to the pins in no particular order? Are these the proper wires to use with the touch-proof connectors? http://f…
