DreamBigDreamLucid
DreamBigDreamLucid
- DreamBigDreamLucid
- CT USA
- 42
- CT USA
I'm seeing now that there are reported issues of the BDF file generation causing the GUI to freeze and to produce corrupted files, which I think it what has happened here since Playback cant use it. Is there a fix for this?
Its there in all its glory the large file but I cant select it for playback and it doesnt appear on my SD card...
Found it! Please disregard. Thank you again immeasurably for all your help!
One last question William, to remove the reference to SRB2 on my EOG (N7 and N8) and my ECG (N9), how do I do this? I go under SETTINGS are "Turn on Advanced, Save, Load, Default"
Wonderful William thank you so very, very much!
That makes sense, thank you! One last question regarding the AGND lower pin on the CYTON - what should be connected here? Should this be the GND channel from the cap? Right now, I have the GND channel from the cap going to the lower BIAS pin on the …
I am a little confused - my EEG cap has a REF ( between PZ and CZ) and a GND (between FP1, FP2 and FZ). Can you differentiate the instructions based on if you are talking about AGND on the Cyton from the GND on the cap? I think thats where my conf…
Is it wrong to have it set up this way per the most recent documentation: Both SRB lower pins connected from Cyton and Daisy via Y Splitter to REF channel, BIAS (black) to GND
Thank you very much for the information; how might the first article differ if I am using the EEG cap in leiu of the singular gold cups? Also, do I need to connect EMG/ECG to the bias pins too? If I do, should I take the bias off the cap to REF or d…
How would I accomplish this if I am also taking EEG recordings on Cyton+Daisy? My ultimate goal is to take EEG channels, EOG, EMG, and ECG. Can you show how I can add EOG ECG and EMG to the Cyton+Daisy with it setup to also take EEG recordings? R…
Hi William, I think it worked correctly, I ordered back in October, all the channels seemed to mimic the same reading, Im not sure if that is helpful to know or not? Maybe its my pin configurations that are wrong?
I will run a test tomorrow and post the data and results, I did not save the most recent one. Thanks!
Isn't there a REF defined on the cap already for this purpose? To clarify, this is the cap I am using: https://shop.openbci.com/collections/frontpage/products/openbci-eeg-electrocap-kit
Thank you Retiutut
+(for context, I am using Cyton+Daisy, without WIFI Shield).
