Default Avatar
DonReed
DonReed
Username
DonReed
Location
Europe
Joined
Visits
19
Last Active
Roles
Member
Location
Europe
  • It uploaded after failing a couple of times. Had to move the BCI right next to the dongle even though it was already close.  At one point it turned off and I thought that I bricked it because it wasn't turning when I switched power on to see if it's…
  • And it compiled. A couple more things I had to deal with: /home/jon/Arduino/libraries/OpenBCI_32_Daisy/OpenBCI_32_Daisy.cpp 1001: byte inByte = spi.transfer((uint8_t)0x00);   // retrieve data 1018: inData = spi.transfer((uint8_t)0x00) | (spi.transf…
  • I moved the file into the directory with file that was complaining. The error disappeared, and it started to show an error pointing out to missing another file (plib.h). ➜  Arduino  find ./ -name 'Board_Defs.h' | grep openbci                       …
  • Hi William, Yes. I've tried using ~/Arduino now, instead of using the directory where arduino binaries are (which also has libraries and  hardware folder). Same effect, just different paths: Arduino: 1.6.9 (Linux), Board: "OpenBCI 32" Build option…
  • Ah yeah, I've installed the chipkit on accident through "Tools->Board->Board Manager" first, it gave me same error. Then I saw that on openBCI tutorial recommendation to use the manual approach, so I `rm-rf ~./arduino15` removed everything el…
  • I want to do neurofeedback and everything I need is in place (OpenBCI, electrodes, conductive paste), except for a way to keep those electrodes on my head. Doing all this work (contacting the seller to request quotes, etc) just to pay 200$-300$ (!) …
