Default Avatar
Deniz_Oe
Deniz_Oe
Username
Deniz_Oe
Location
Austria
Joined
Visits
44
Last Active
Roles
Member
Location
Austria
  • P. S. can we be sure that the dongle is doing okay? if not, is there an easy test for me to see if it gets the right signals?
  • @retiutut thank you so much! they reached out to me already! As soon as I get the new board I will post some screenshots, hopefully with the correct signals this time ?
  • @retiutut said: Those spikes look like "low battery" spikes to me. Also, channels 1 and 2 aren't railed. Hopefully, no one around the device is actively using a cell phone ~1-2meters or operating radio equipment. I guess wait and tr…
  • okay, I will definitely keep posting screenshots in this thread as soon as I get the new power supply! I hope everything will work out in the end, but yeah otherwise I would be really grateful for help with the replacement! best, Deniz
  • Okay I will try to swap them! thanks for explaining how to use them :-) Yes, me too, I'm just learning about EEG scans, but that doesn't look like normal signals. I bought the batteries new and also exchanged them with another set of 4 fresh batt…
  • thanks for the quick reply @retiutut ! So yes I am using it with a Mark IV, 8 channel set. I did try my best so that the electrodes touch my scalp, however I have thick hair. So that's why I now tried the headset on my brother with short hair and …
  • @retiutut said: if you still have issues check tech support with OpenBCI. I'm part of the support team, and I think more info is required before a replacement would be issued. No worries! @Deniz_Oe Try Bill's suggest…
  • hm... neither of both is the case.. do you think my cyton board could be malfunctioning? maybe I should contact OpenBCI, because I just received the board about a week ago
  • with the battery pack that came with the cyton. Do you think that could be a problem? Maybe as a sidenote, even when I used the batteries for the first time, FP1 and FP2 were railed...
  • Hey! After resarting the GUI and turning the Cyton on again, I have now kind of different signals on all channels compared to normal... And no signal on C3 and C4.
  • thanks for the quick replies! I will check out the github on the other post and hope to get to change it accordingly
  • thanks again! one last thing: I've read that there might be problems with receiving goods in Europe. What exactly happens if I buy OpenBCI products and they get captured at the customs? Will I have some sort of support from your side? best, De…
  • Hey William, Thanks so much for the answer! The cVEP example is highly impressive! So, as far as I understood, I could buy a Ganglion 4 channel, try my first EEGs, and afterwards use it for ERP EEGs? Since I have a 3d printer, I would also lik…
