Default Avatar
DaveD
DaveD
Username
DaveD
Location
Phoenix, AZ
Joined
Visits
7
Last Active
Roles
Member
Location
Phoenix, AZ
  • Thank you and I did look at the video. Problem with this solution is that if there is a screen in front of him so he cannot see where he is going. This would be a real problem when crossing the street or moving around a restaurant. Currently he is u…
  • Thank you for your help. I just received the technical specifications of the Omni display and this is what I have found out. The interface to the Omni display is a 9 pin din connector. Using a digital mode, I just need to output voltage to one of fo…
