Danb
Danb
- Danb
- 50
@brain- Do you thing I could get that file again? The link has expired and I need it once more...long story lol.
Also, in Ubuntu 14 you can run it straight from the GUI if you open up Nautilus and select Edit, then Preferences, then Behavior, then select Run executable files when they are opened. By enabling this you don't have to use the terminal to run the …
It worked, thanks!
I'm using processing 2.2.1. I did replace the jssc.jar with the updated version you linked to. I didn't download processing initially but I just tried it and it didn't help. I still don't know how to launch it from processing though? I didn't kn…
