Default Avatar
CyK
CyK
Username
CyK
Location
London
Joined
Visits
31
Last Active
Roles
Member
Location
London
  • Hi, Thank you for your reply and patience! I can see the EEG signal through other tools by saving the original data in the bdf file, but the signal is not intuitive or clear. The reason may be that there is no gain adjustment and filtering proces…
  • Hi, Thank you for your reply and support! I tried to use the LSL protocol in the Networking component, TimeseriesFilt, to stream and save it as an XDF file. Then, I plotted the channel data and could clearly see the EEG signal and changes. But wh…
  • Can openvibe receive and process signals other than EEG signals? Like ECG, EMG. .
  • This is I tried to test the mindaffectBCI, and I run "python -m mindaffectBCI.online_bci --acquisition fakedata", and it shows like the screenshot shows:
  • Hello, wjcroft Recently I set up the mindaffectBCI on my ubuntu system, but I can not sucessfully set up, is it can work on linux system? Or I use a virtual window system in my ubuntu, and to do the BCI work, is it can be worked?
  • Hello, wjcroft For mindaffect bci, should I use the GitHub link you sent me to build the environment? Or should I build it through the process of mindaffect’s official documentation website? Because I saw "We no longer maintain and provide suppor…
  • OK, I will focus on this. I'll keep on it. Thank you for your help!
  • @CyK said: So can I experiment by using mindaffect instead of openbci_gui? Because mindaffect has better results? For external triggers, can I use LSL to label the data, and if it can work, need i to input the LSL library to Cyton board? …
  • Thank you for your help!
  • So can I experiment by using mindaffect instead of openbci_gui? Because mindaffect has better results? For external triggers, can I use LSL to label the data, and if it can work, need i to input the LSL library to Cyton board?
