Cristhian
Cristhian
- Cristhian
- 125
Hi asadullah01, Have you tried to stream OpenBCI Ganglion data through the Lab Streaming Layer (LSL) using OpenBCI GUI with Processing? I look forward to your answer.
Hi asadullah01, Excuse me if my answer is late. I can say about it is that the Ganglion Board does not have an FTDI chip that allows receiving data using Python and COM Ports. If you want to redirect the data from OpenBCI GUI to MATLAB, you could …
William (@wjcroft), hi. To be honest, I would like the OpenBCI team not to "forget" Ganglion users. Several of the great functionalities are successful in Cyton but not in Ganglion. I say this because, for example, the transmission of Ganglion …
Hi William (@wjcroft) I attached the link that contains an Excel file with data from a Ganglion transmission. There you can see that channels 2 and 3 do not show DC offset, but channels 1 and 4 do. What could be happening? https://mega.nz/#…
Hi William (@wjcroft) I'm surprised because I've always seen the DC offset in all the tests I've done with Ganglion and MATLAB through LSL. Further, that DC offset is very dynamic in the time domain. I attached image of the signals collected: …
I would like someone to tell me if the filtering functions that appear in Networking actually work. I have a Ganglion card for several months and I have never been able to receive the data respectively filtered in MATLAB. My greatest desire is to b…
@pushtheworld Yes, now LSL works fine with Ganglion and Processing! Thanks.
Hi @pushtheworld. It worked for me. Thank you very much.
I downloaded and install Processing 3 and OpenBCI_GUI-master from Github. I draged OpenBCI_GUI-master into Documents/Processing and I draged too contents of OpenBCI_GUI-master/libraries into Documents/Processing/libraries. I executed a pde file and …
Hi! @pushtheworld. The GUI still freezes with Ganglion and LSL protocol. I noticed that in Synthetic (algorithmic) mode, the GUI froze with LSL when I selected 4 channels, but this does not happen with 8 or 16 channels. Maybe that explains a bit w…
Hi! I also have a Ganglion board and the upgraded GUI (July 20) still freezes with LSL. By the way, I've tried it on my PC ASUS (Win10). Screenshot: https://prnt.sc/fynrs6 Thanks.
I have a Ganglion board. The OpenBCI GUI works very well and I am also using a CSR 4.0 dongle and I have downloaded and installed the CSR Harmony Wireless Software Stack. I followed the repository instructions: https://github.com/OpenBCI/OpenBCI_M…
