Cassani
Cassani
- Cassani
- 13
Hi Ozberk, What kind of configuration as you using for the different channels? As @wjcroft suggested, please share what commands are sent to the board, and what the boards returns. Best, Raymundo
Hey, Testing the OpenBCI GUI to stream over LSL from the Cython board, and I was able to replicated the 23 s delay. My system is W10 64-bits, and the OpenBCI GUI is 4.1.7, and the LSL stream was read from Python3 using pylsl. Later, I used Open…
Hi @Ivan, The idea of the LabVIEW toolkit https://decibel.ni.com/content/docs/DOC-40837 is to communicate the OpenBCI board with LabVIEW without the OpenBCI software. This will make the process of having EEG data in LabVIEW very straight forward R…
Hello plabita6, As JakeStew and William (wjcroft) mentioned, there is no need of using the NI USB6501 device, you already have the digital EEG data as serial stream. The flow of EEG data is the following: The input for ADS1299 is analog EEG data…
Hello plabita6, I would like to have more information about what you want to do to help you better. 1. The EEG circuit you are making, it based in the OpenBCI diagrams to acquire and amplify signals from the electrodes, right? 2. The DAQ that you …
Hi William, Yes, the toolkit will work with the student version offered by Sparkfun. You may want to see this Student Edition: http://sine.ni.com/nips/cds/view/p/lang/en/nid/210867 a little bit more expensive (link) but it include some toolboxes. …
