CJP
CJP
- CJP
- 39
@pushtheworld I'm sorry. I'm new to github apart from downloading the .zip files .. i think I sent you the pull request now.
@pushtheworld I suggested a edit via github, Check whether I did the right thing . .
WoooHooooo yeeeeeee I see DATA used chipkit 1.3.1 Thank you very much @pushtheworld @mesca and @KDCTyler .. May be the firmware update wiki should be updated. Anyone know how to suggest the edit to admins ?
1.8.4
@mesca yes its the same. ⸮I V3 8-16 channel On Board ADS1299 Device ID: 0x00 LIS3DH Device ID: 0x00 Firmware: v3.1.0 $$$ I went back to the 1.xx firmware earlier but the output was all zeros.But I can't remember about the IDs i…
As I remember, There was a solid red on TX led when streaming. Its same after the firmware update. Solid red on TX LED when I start the stream.
I flashed the latest firmware again and now the serial connection is ok in GUI. But still no data from the sensors or the accelerometers.
FTDI driver is up to date, I will check the board with a another computer ASAP. But I tried it with my windows and Linux OSs but the result is same.
Hi William, Thank you very much for your replay. OpenBCI GUI seems to have a problem of connecting with the board. It outputs a error saying "Error reading from the serial port, Try different one" . I am attaching a screenshot of the terminal an…
