Default Avatar
Bruce
Bruce
Username
Bruce
Joined
Visits
12
Last Active
Roles
Member
  • @biomurph Thanks. I have made a stupid error. I have hacked the board and use USB-to-TTL to communicate the board with the PC. All of the problems I metioned on May 21 are solved by simply replacing the bad-quality USB-to-TTL with a better one. Tha…
  • @biomurph Thank you for your comments. I have solved the problem. As your instuction, I use MPLAB X to bootload the PIC32, and find out the external crystal is not working because one capacitance besides the crystal happened to break down. After the…
  • @wjcroft, Yeah, I have looked through the thread your mentioned, and I can't find helpful thing for my problem.   Thanks all the same.
  • @biomurph, I have tried the MPLAB X IDE v2.35, the UDB32-MX2-DIP.hex file is import from the File>Import>Hex/ELF..File, and the hardware tool is chosen as PICkit3/ SN:BUR132284452. And I don't do anything more in the procession of importing t…
