Bonzo
Bonzo
- Bonzo
- 47
Hi William, I tried out the bias and now it seems that is working properly! Thank you, I already red all the tutorial, but from my understanding I was thinking that for a single differential channel the ground pin was not necessary! Definitely wro…
Sorry for posting three times in a row, but I want to add further information, so that maybe I can be better helped. I just acquired the raw data from the Cyton board without any filtering. As you can see in the image below, there are some impulsi…
In order to add more detail to my last post, I just acquired the signals from the cyton without connect anything to any pin. Here you can see that the unwanted spikes are still present: And in this zoom you can see that such spikes all have t…
Hi William, thank you for your answer. I connected the electrodes in the following way: * 4 differential channels (channel = couple of electrodes connected to N and P pins); * ch1 -> 1N & 1P, ch2 -> 2N & 2P, ch3 -> 3N & 3P, c…
Thank you!! :-)
Thank you @pushtheworld ! How will be communicated the day the wifi shields will be on sale? Is there a possibility to pre-order?
@pushtheworld that's great! :-)) Does "great sample rates" mean at least 1 kHz? Will the sample rate be settable by command? Thank you for your precious work!
Thank you wjcroft. Anyway, I would like to know if that decoding with matlab code is ok or not.
Ok, I got it! Thank you! Another possibility should be to connect the Serial 1 of the board to an external bluetooth module, do you know (or do you have) any tutorial on how to hw&sw implement such solution? (something with more information tha…
Ok, maybe I have no very clear ideas (I am absolutely not an expert), so I apologize in advance if I am wrong with very basic concepts. As far as I was able to understand: Since my goal is to reach 8 channels at 1kHz, if I don't change the baud ra…
@pushtheworld Yes, actually I could try to first reprogram the Pic32 communicating at 115200 baud. Anyway, I was following the "correct" procedure as suggested in the guidelines: 1. reprogram the device radio2. reprogram the host radio 3. reprogr…
Autoscan didn't work: "Error connecting to the serial port". I don't think the problem is the wrong channel, because when I go back to the baud rate value of 115200, then it works again. I would say that radios are not able to communicate at higher …
Yes I used the GUI to verify the communication, and the response from the GUI was negative.
I have tried to update the baudrate of the radio "device" and "host" and the sample rate of the "pic", but for some reason it doesn't work: once the radio host and device are "flashed", it is not possible to communicate with the OPBCI board to upgra…
Yes, I am absolutely interested in 8 channels at 1 kHz. What do you mean exactly with "use external serial port [...] using that same code"? Thanks.
Thank you very much wjcroft and pushtheworld for your kind interest. Unfortunately I am located in Europe, Italy. So, if I got it, uploading the code you linked from github will make the OBCI board working at 1000 SPS? or do I have to use it with …
