BCIStudent
BCIStudent
- BCIStudent
- UK
- 8
- UK
@wjcroft said: Your photo shows that your notch filter is off, did you try turning that on? So you in doing your own filtering of the raw recording, you will want to use BOTH a notch and bandpass. There wasn't a noticeable difference havi…
Thank you, I hadn't seen these diagrams before. I'll try it out in the coming weeks - thanks.
@wjcroft said: The recommended approach, is to use Brainflow library from Matlab, https://brainflow.readthedocs.io/en/stable/Examples.html#matlab Thanks for the code example page. I downloaded the "matlab_package.tar" and placed th…
@chipaudette, I was looking for filter settings and configuration, which brought me here. As you are responsible for the filters I got a question for you: Is there a way to use the GUI to record filtered data rather than just the raw EMG? Also is it…
@wjcroft said: Are you performing a pre-filter operation on the data? Such as a bandpass from .5 Hz to 45 Hz? Cyton CSV recording file is raw unfiltered. What you see on GUI screen has filters applied. Thanks for the reply. I had the GUI …
