Arale
Arale
- Arale
- 23
Hi, here a picture of my Ultracortex V2. I bought dry electrodes from Florida Research Instruments. I measured the impedance with the Processing GUI and I found around 8 kOhm with the dry electrodes and 34kohms with the original wet electrodes comin…
William, Jérémy thanks! Version 2.12.00 of the driver was installed, I don't know if the system did an auto update. Anyway I tried the last one (2.12.06) and the previous one available on the FTDI website (2.10.00 and 2.08.30) but nothing fixed th…
Hi, thanks for your answers. When I flashed the bootloader a few days ago I used exactly same setup you proposed and I had a message saying the process went well. I think this was OK. After uploading with mpide, the blue led wasn't on when I swi…
Hi All, I'm interested in the way you reflashed the bootloader into the PIC. I'm using mplab ipe and a pickit 3, I could program the bootloader UDB32-MX2-DIP.hex without any problems. However when I try to upload the openbci_32bit program throw th…
