Anete
Anete
- Anete
- 56
Hello! For some moment I thought that swapping GND and REF helped, but later I understood that I still receive 70% accuracy or less. Is there some app/code/game or something developed that I could try out using my eeg device to just understand if m…
Thank you for your answer! Yes, I know that I have two pictures with just different scales, I just wanted to understand if the signal amplitude is larger enough to be considered normal as I have read somewhere that EEG signal has to be in range o…
Is the 100 microvolt signal considered to be normal? I have way less also in OpenBCI GUI. Is this not normal range? Regarding reference electrode, I will try to find a way how to check how it works when placed on ear lobe.
Hi! Thank you for your answer! Regarding electrode placement and reference electrodes, I have gel free EEG headset; therefore, it is not very flexible towards electrode placement, including reference. However, I will try to find a way how to cha…
