Anastasiya
Anastasiya
- Anastasiya
- USA
- 42
- USA
I just wanted to add that I have never used AA batteries or the included battery pack before with this headset - I've instead been using a rechargeable 3.7V 500mAh battery from Adafruit (https://www.amazon.com/ADAFRUIT-INDUSTRIES-1578-Lithium-Polyme…
Thank you for the response. @retiutut said: The leads need to be connected to a human with earclip electrodes. This crucial detail is not mentioned. I would try again with the Cyton and earclips connected. I had the headset on my h…
https://openbci.com/forum/index.php?p=/discussion/2367/strange-synchronous-ecg-and-eeg-artifact The above post seems to have a similar problem - running the headplot may be causing/contributing to this issue. I tried replacing the head plot with …
This better shows the waveform: Also please note that it seems after recording activity normally, at some point all the channels flatline, and after a second or two they show this unexpected waveform.
Everything seems good. Steps: * Tried to launch hub manually, received error: ./OpenBCIHub: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory * Ran the following command: sudo apt-…
Hello again, I've been trying to run the GUi on the Ubuntu 18.04 LTS OS on my laptop (i7-7700HQ processor, so shouldn't have the ARM64 architecture problems like before). At first the GUI was just a black screen when I ran ./OpenBCI_GUI or sudo ./O…
Yup, I'm using the Jetson Nano mainly for its GPU + portability and because of all the compatibility + optimization with a bunch of different frameworks/models. My general idea was to make an offline mobile device with a headset and gauntlet. The se…
I also have a documentation change question related to accessing the EEG data via python. Under "Software"->"Developed by OpenBCI" there used to be a "Python and OpenBCI" section, but it is now in the deprecated documents with the following heade…
Thank you very much for all of the information, William - it's very useful. I've skimmed over the brainflow documentation and will be looking at it in more detail tonight. On a related note, I see in several recent posts on the OpenBCI forums tha…
Following up - I'm still experiencing issues with getting the OpenBCI GUI running on Ubuntu. Could somebody please list the hardware/ OS/ installed package requirements for running the GUI (or a link to a reference which does so)? Most importantly, …
I was still having this problem, and now I'm not sure if I am. I was busy most of last week, so I didn't do anything after my previous post until this morning. Below is a transcript of what i've done: @wjcroft said: Are you still getting er…
I definitely messed something up with the RFduinos somewhere along the line. I now have the RFduinos functioning fine, but can't flash the firmware onto the PIC. These are the steps I took: In Arduino 1.5.8: (updating RFduinos' firmware) * […
Quick update. I followed the steps for V3 (the process is so automated and so user-friendly, I love it) and the firmware compiled without any issues. However, when I tried to flash the firmware onto the board's PIC, it didn't work (target not found)…
Yup, sorry for the confusion. I was using https://github.com/OpenBCI/OpenBCI_Cyton_Library/blob/master/UPGRADE_GUIDE.md as my main guideline for the order of everything, https://docs.openbci.com/docs/02Cyton/CytonRadios for reprogramming the RFduino…
@wjcroft said: DId you see the note about 64 bit Linux on the chipKIT page? http://chipkit.net/wiki/index.php?title=ChipKIT_core#1.29_Auto_install_via_URL_from_within_Arduino_IDE_.28latest_version_chipKIT-core_v1.3.1.29 Yes, I ran …
I don't use Linux often, so I can't navigate it as well, but my primary machine does have Ubuntu 18.04 64-bit dual-booted on it for occasional projects. I installed Arduino 1.8.10, downloaded and extracted the OpenBCI firmware/libraries and the linu…
@wjcroft said: The previous comments on the other thread indicate there is confusion / conflict over whether the toolchain is installed in Windows local or roaming pathways. Possibly same thing is happening on your system. I don't see any…
I see that core.a error listed in the other thread with a different path of "C:\Users\Marcelo\AppData\Local\Temp\build314722887501305307.tmp/core.a", but I now realize that they were compiling with IDE v1.6.5 according to the screenshot, and that co…
Just as a note, those single backslashes in the italics are actually double backslashes. i.e. "C:\Users...\AppData\Local\Temp\arduino_build_389561/core\core.a" is actually "C:\\Users\\MSI\\AppData\\Local\\Temp\\arduino_build_389561/core\\core.a"
I uninstalled arduino and went to "C:\Users...\AppData\Local\Temp\" - this location does not have any folders labeled arduino_build_XXXXXX. I reinstalled Arduino 1.8.10, went to the same location, and there was again no such folder. Launched the IDE…
Hello, I've tried to get the code to compile after manually installing the correct chipkit-core version and got a new error: "pic32-g++: C:\Users...\AppData\Local\Temp\arduino_build_915650/core\core.a: No such file or directory". After Googlin…
Thank you for the relevant link and sorry for not checking through the forums properly beforehand. I'm assuming the most important takeaway would be: "Folks, sorry for the confusion. @Marceloruiz has the correct solution to the compile errors. No…
I used the 1.5.8 IDE for the RFduinos, then uninstalled 1.5.8 and reinstalled 1.8.10 before trying to update the board, so I've been having the compile errors with 1.8.10
Thank you for the clarifications, William! I had to go out of town for a bit, but am back now and am trying to update the firmware again. I successfully updated the two RFduinos with the radio update instructions and moved on to uploading the main b…
