Amiya
Amiya
- Amiya
- Singapore
- 22
- Singapore
I realized even the accelerometer appears to be stuck
I realized I am also facing the same problem. I did not check the accelerometer but now when I did it appears exactly like here. Here is the thread: http://openbci.com/forum/index.php?p=/discussion/992/impedance-check-all-electrodes-appear-to-be-flo…
Not really, the board still does not appear to be working. I also noticed that the impedance appears to be stuck at 0K and doesn't change even if nothing is connected to the pins or if the pins are shorted with ground or ref! Random signals appear o…
No I do not see any ECG or EMG signal...I get the same signal irrespective of if the electrodes are connected or not. Yes I made sure that switches are set in referential mode. Thanks
@wjcroft It still does not work. Impedance appears to be 0 and I get random voltages as high as 700 uV even when nothing is connected to the electrodes. Touching the electrodes has no effect on this signal.I am wondering if the unit is faulty.
Thanks @wjcroftSubmitted the issue. Cheers
Hi @wjcroft Yes I am following the right one. In fact I can connect to the device but for some reason I just don't receive the 'sample' event triggered. See the code below: const Ganglion = require('openbci-ganglion').Ganglion; const ganglion…
