Amir3022
Amir3022
- Amir3022
- Egypt
- 4
- Egypt
Yes I read the whole thing, but still kinda confused why I can't get results in other experiments. Will try to get another person to test the kit again soon and see if that changes results. Thank you for your time and effort.
Okay, so new updates. I am still reading into MindAffect and haven't been able to fully test that yet. But I tried the EEG test [eyes closed alpha] you provided on another person. And again I couldn't generate alpha waves, and even tried the ssvep m…
I have already started reading into their documentation and it looks good so far. I hope this actually works. At least it will prove for last if the problem is with me or with our Cyton board so I don't waste anymore time trying to tinker with it. …
Also one more thing, could this be a bad firmware problem? Like can reflashing the cyton board with the firmware make perform any better? Or that isn't effective in my case?
For SSVEP, I used the code provided by chip for the video file generation, as I know real time program won't be very accurate and tried a LED array, but was very uncomfortable. But then again it didn't generate any correct data which had peaks at th…
Its kind of hard to meet in these days cause of covid restrictions here. But I will try to see if that is possible in the coming few days. But beside alpha waves, aren't there any other methods that I can use to check if the heads properly read EEG …
Regarding the tutorials you mentioned, yes I setup the Cyton board the way its explained in the document. And I aslo tried to generate Alpha waves the same way that was explained in the EEG tutorial using same wet electrodes placement, but I get no …
Okay so now I changed the batteries and it works again, the blue LED isn't blinking and its stable. But the thing I noticed about it there are still very large amount of noise present in the signal I record. And also what ever disturbance happens in…
I managed to test the battery pack by connecting some wire and testing it using a LED, and it wasn't outputting any power. After further tinkering, I found some of the metal contacts in the battery pack were getting eroded, and maybe there was no fu…
I tied new batteries and still the same, no turning on. It doesn't even make the tunning sound it used to make. So I am kinda confused now if its even working at this stage. Thank you again fro your reply.
Okay I will try that and come back to you with the results. Thank for your time and reply.
Yes exactly, I am using that. I tested the batteries alone on other devices and they work. But I couldn't test them in the battery pack as I don't have any other device using the JST 2-Pin connector for power input.
Well unfortunately, I am back at square zero again. The cyton refuses to power up. Have even tried to change the batteris but still not powering up at all. My last hope would be getting new Lithium Ion batteries and see if that will make it work. We…
Regarding the left it for somedays part, it didn't work out of the gate, I just left it on PC mode and it kept making this tunning sound. Then it powered up on its own. And since then it just works whenever I turn it on no tunning sound again. The …
Okay so new updates. I still didnt manage to get it to work, unfortunately. Wich made me question if maybe there was something wrong with the cyton board itself. I disconnected all the wires and left it only connect to the battery pack. I got these …
Okay then I will continue testing on windows and see if I can get better results. Thank you for your patience. Will keep this post updated with any new thing I try.
Regarding the eyes close part, I just got coffee a few hours ago so I think the effect of that is still present in my system, so maybe I will retry again tomorrow morning before I get my coffee. Regarding the lag part, I have already adjusted that …
The Ultracortex is 1 year old and it was used for another project before ours, so it wasn't used extensively fro too long. But the thing I noticed is that even with dry electrodes, the device wasn't just behaving right. For example I couldn't genera…
Okay i left for somedays and it somehow works now. But not quietly unfortunately. Iam using the ultracortex IV with the dry comb electrodes. When iam reading data using the OpenBCIGUI, if I read from the headset without wearing it, it's placed on th…
I will try recording new data tomorrow from different subject to see if that will make a difference in the data we generate. As well as checking the dry electrode combs and making sure they aren't worn out. And maybe we will consider buying new ones…
Thank you for your reply really appreciated. I will read more into all the links and threads you have provided to me, and see if maybe I can do better next time I use the headset. I am still searching for the SSVEP thing. I am not even sure I am d…
