Alexander_Zuest
Alexander_Zuest
- Alexander_Zuest
- Switzerland
- 74
- Switzerland
@retiutut > @retiutut said: Here is a workaround to stream LSL without using the GUI for now: https://openbci.com/forum/index.php?p=/discussion/comment/13072#Comment_13072 I implemented the script proposed there, but as shown in …
@retiutut I'm using the scripts (lsl example and cyton) provided by @rai_santo in combination with the files from https://github.com/openbci-archive/pyOpenBCI. I was not able to fix the jittering this way as seen in the screenshot below. Is there …
@wjcroft @retiutat Thank you so much for your support! I will take your recommendations into account during my trials. I got the 40-50K Ohm from here: https://openbci.com/forum/index.php?p=/discussion/comment/13135#Comment_13135 I think it is a…
I tried to adjust all electrodes for a better fit, jet it seems I was not very successful. As one can see channel 2 and 6 (Fz and Cz) are very noisy. But in terms of impedance even channel 1 and 3 produce very high values. Channel 1 is Fpz on my for…
The range of the impedance remains essentialy the same. Yet the signal did some funny things link being railed at the start of the recording on most channels then turning okay, not stoping the impedance measurements when told to do and being near ra…
I have the two ear clips attached to the bottom pins of Bians and SRB, their surface is completely grey, so the coating is still intact. In Addition, I checked their connection to the board. Unfortunately, I have no additional ear clips at my disp…
@wjcroft said: Alex, what is your definition of 'pure' hybrid? I'm not clear on the use of pure. I do understand you are wanting to multiple paradigms simultaneously. What is an example of non-pure hybrid? "pure" basically just means that…
Use the 'devel' github branch, it is the only one with a working installation on matlab2019b (you will also need a visual studio compiler). https://github.com/Metasoliton/BCILAB
@ThreeForm @wjcroft Thank you very much for your answers and support! Regarding the material selection I will consult our specialist again and we will evaluate if we will use SLS, PETG or ABS. We will also keep your tips in mind, thank you! In t…
