Default Avatar
19942214
19942214
Username
19942214
Location
South Africa
Joined
Visits
15
Last Active
Roles
Member
Location
South Africa
  • Thanks for the link! I am currently looking for a way to work with brainflow in python and then communicate with my ESP32 in Arduino. I saw that you can control an Arduino with python by using PySerial. Is this something you have worked with in t…
  • Would this threading be possible with python and micropython?
  • Thanks! I have already started with the brainflow installation on Visual Studio. I just installed the brainflow nuget package.
  • Thanks for all your comments! I already created my audio with Audacity and it worked well for what I was trying to achieve for my audio. I will go through the link you posted William. What software program would you suggest working with when writ…
  • That is great! Thanks for the link and all the advice! I will see what I can do. Threads will be possible to use without Linus right? I have windows, but I just want to double-check that it will be fine? Kind regards Elke
  • Thanks for the quick reply. Yes, I do not want to use a mic in my project. So will it then be possible to write in the same code script the audio for the Bluetooth earphones and the processing of the EEG data of Brainflow? My knowledge is more C+…
  • Thanks for the advice RW! The reason I am skeptical about using Bluetooth earphones (obviously it will be most ideal) is that I need two different sounds playing into each ear. That is why I am thinking of instead of using off-the-rack Bluetooth e…
  • Thanks! I was thinking about using an ESP32 wroom32 module to do the Bluetooth signaling for the audio. I want to use stereo audio for my earphones and play two different sounds from each earphone, but I think that can be easily set with a stereo au…
  • Yes, I understand that the processing part should be on the laptop. I want the music to play wirelessly from my laptop to my earphones and that is why I want to make a subcircuit for the audio. If the EEG is in the desired frequency band then a 't…
  • Thanks! I will have a look at those links but do you think it would be possible to incorporate the ESP32 to do the audio circuit part of my project? By that, I am meant to run the Cyton board and the ESP32 MCU from the same script?
  • Thanks for replying, William. I understand what you are saying. Thanks for the heads-up! Will it be possible then to alter the Arduino code of the Cyton by adding a parallel system where an ESP32 MCU is controlling the audio? The code will then be…
