Python Error: [print] not found or could not be loaded. Check name and requirements
alirazaaliraza Islamabad
edited December 2018 in Ganglion
We are connecting ganglion device with OpenBCI_Python but having problem related to plugins not found or could not be loaded.
Command :
sudo python user.py --board ganglion --port E9:2A:73:ED:89:B1 --add print
But it shows following error :
"Error: [print] not found or could not be loaded. Check name and requirements"
In our OpenBCI_Python folder, all plugin interfaces are present. Yapsy and all required packages are also installed in python, but still i am not able to find the solution.
Kindly help us in solving the problem.
Best Regards,
Ali
    This appears to be Python 3 related, as shown on the issues page.
    There might be some conflict with the symbolic name for the plugin 'print', conflicting with the built-in language function 'print'. Can you try renaming the plugin, to for example, 'printsample'.
  • alirazaaliraza Islamabad
    The python version i am trying it on is 2.7. I don't think renaming will help. The problem is actually in loading the plug-ins from the directory. The same error is shown if instead of print, streamer.lsl is used as plugin.
    Under the field plug-ins found there is no plug-in listed. Although all plug-ins are available in openbci python directory.
