Wired Cyton. Device connected on GUI but no data stream is displayed
Hello everyone,
I bought the parts and made the board using the gerber available on Git.
I mounted the OpenBCI Cyton with 8 ch, and I flashed the FW using the Pickit.
I can connect the GUI with the board, but I can not see the stream of data from the OpenBCI GUI.
I'm using a wired connection to the PC, using a USB-UART converter instead of the RFDuino (because I couldn't find it to sell).
I know about the noise and the dangerous of not using a isolated connection like bluetooth, wi-fi or even with an isolator, but now my goal is
only to see it working and after I'll acquire the isolator or develop the firmware to another bluetooth chip.
Using a serial reader the output from the board when its starts is:
OpenBCI V3 8-16 channel
LIS3DH Device ID: 0x0
Firmware: v2.0.1
I can connect to the board through the OpenBCI GUI, but when I start the data stream the software does not show me data.
I have another informations and I can post them here, just ask me
Do you know if the RFDuino change something in the data stream?
Thanks in advance for your patience and help
Did you end up getting your wired connection working @geraldo ?
