Bluetooth connection doesn't show up in GUI with Ganglion board
mh0mh0 Watertown, MA
edited December 2018 in OpenBCI_GUI
I just received my Ganglion board. I downloaded the OpenBCI_GUI application from the link on the openbci.com site, and I'm trying to follow the getting started tutorial on Linux x86_64.
The GUI opens when I run the OpenBCI_GUI executable that was included in the zip file. When I click on LIVE (from Ganglion) under DATA SOURCE, I don't see the PICK TRANSFER PROTOCOL box that the tutorial shows. I just see a message "Unable to establish link to Hub. Checkout tutorial at ... ", which is the tutorial I'm reading.
On the command line, I'm able to connect to the ganglion with hcitool:
$ hcitool -i hci0 lecc --random <my device bt addr>
Connection handle 3585
And the blue light goes from blinking to solid.
$ hcitool con
Connections:
< LE <my device bt addr> handle 3585 state 1 lm MASTER
The only error I can see is that when I start OpenBCI_GUI I get this
$ ./OpenBCI_GUI
Screen Resolution: 3840 X 2160
For more information about how to work with this code base, please visit: http://docs.openbci.com/OpenBCI Software/
Local Version: 402, Latest Version: 402
GUI is up to date!
Graphics & GUI Library: ControlP5 2.2.6 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
attempting to load images for presentation...
DONE loading images!
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:211)
at processing.net.Client.<init>(Unknown Source)
at OpenBCI_GUI$Hub.startTCPClient(OpenBCI_GUI.java:13075)
at OpenBCI_GUI$Hub.<init>(OpenBCI_GUI.java:13051)
at OpenBCI_GUI.systemUpdate(OpenBCI_GUI.java:1231)
at OpenBCI_GUI.draw(OpenBCI_GUI.java:596)
at processing.core.PApplet.handleDraw(PApplet.java:2429)
at processing.opengl.PSurfaceJOGL$DrawListener.display(PSurfaceJOGL.java:866)
at com.jogamp.newt.opengl.GLWindow.display(GLWindow.java:759)
at com.jogamp.opengl.util.AnimatorBase.display(AnimatorBase.java:452)
Instantiating hub object...
But that looks like it has something to do with networking, rather than bluetooth?
Any suggestions would be appreciated! Thanks.
