Ganglion latency tests via external markers or analog input
Hi all,
In I few days I will get my Ganglion board and I started looking around for ways to test the latency between the generation of the signals and the moment they are received by my processing algorythms. This requires to get some external digital trigger or analog signal and add it to the output stream. Both options are avialable for Cyton boards. And, as I understood from other discussions, with the ganglion board it should be possible to analogread() a signal and add it to the data stream.
Has somebody found a way to measure the latency of this board?
Thank you for your time,
regards,
Leonardo
