Problems to detect ERP in EEG Signals
in Research
Hello together,
two students and I have been working with the OpenBCI Mark VI Headset since April 2018. In our project at the University of Heilbronn we try to detect finger movements. To recognize the movement of the forefinger we use an external trigger on digital input D17. So, we see in the recorded data the input change from 0 to 1 if the finger pushes the trigger button.
In Psychotoolbox for Matlab, we prepared a presentation that shows the test person arrows to the left or right. Depending on the arrow the test person pushes the corresponding trigger and hold it for 2 seconds. This happens for the left forefinger 119 times and for the right forefinger 121 times.
Our impedance of the electrodes C3 and C4 (10-20-System) are 30k ohm. We only look at these two channels with a sample rate of 250 Hz.
In preprocessing we filter the signal with a bandpass of 4 to 45 Hz. Then we search for changes of the digital input from 0 to 1. Then we cut the signals into pieces of the same length.
Now we look at each trail and the mean value of all trails. We expected to see ERPs on the signal, but it seems we only see random noise.
The picture shows the mean value of the movement of the right finger. We discussed the results with our professor, who has a lot of experience with EEG signals. She said the results are not good enough to detect movement. Her first assumption was that the impedance of the electrodes is too high. In this forum, however, it is written that an impedance of about 50k ohm is sufficient.
So we're a little confused why our signals look so bad and we can not read any information from the EEG signal.
Has anyone ever done a similar project?
Does anyone have tips and advice for us, what's wrong with our approach?
Thank you for your time.
best regards
Julian
William,
thank you for
the answer.
We tried
the gold cup electrodes last week in two measurements. We used one electrode at
the position of C3 and other one at C4. BIAS and SRB was connected to the left/
right ear.
Again, we like
to detect the movement of the left and right forefinger. This time we only
repeat each movement 50 times and calculate the mean over all movements of each
kind.
Our
impedance of the electrodes C3 and C4 are 66k/60k ohm.
https://picload.org/view/dclodwpc/leftfinger.jpg.html
Unfortunately,
the results do not differ in quality.
So, the
question remains why our signals look so bad and we can’t read any information
best
regards
Julian
