my unit is cyton open bci and conneded dongle to pc(64 bit window 7) after runing processor 3.4 getting waited for 5000ms error ang GUI shows blank screen.
Is this a new Cyton just purchased? Have you tried connecting to it from other laptops?
Sometimes when the GUI shows a completely blank / black screen, it means your OpenGL (graphics drivers) from the laptop manufacturer are out of date. What is your definition of "shows a blank screen"?
Does the COM port show up in your Device Manager when you plug in the dongle? Conversely it should disappear when removed.
Com port display but got Failure communication time out device failed to open host poll
After processing3.4 set up
select c:\user\name\mydocument\processing\openBCI_GUI\ openBCI_GUI\ openBCI_GUI.pde display openBCI_GUI but after running it shows waited 5000ms….. error and GUI screen is blank
_____________________________________-
When I try this procedure first time I got waveform after connecting electrode, So its may not be driver issue; but now when I install new version GUI 4.02 its not work so I again tried older version 3.4 and used HUB respectively still both are not working.
In other PC windows 10 and 64 bit configuration I down load all software and I got output for older version after few days openBCI_GUI folder is deleted from processing folder
Version Open BCI GUI 3.4 and OpenBCI_GUI 4.02
in program file after openBCI_GUI.exe
