which GUI to use with OpenBCI 8bit clone?
Hello;
Im working on Ads1299 development board but after some research I found that its own GUI and setup is not for mine so I decided to interface ADS1299 daughter board with Arduino Uno and made the jumper setting on ads1299 daughter board according to the openBCI 8 bit v3 schematic. Then using the buffer ics between arduino and ads1299 for voltage conversion I succeed to get the device id and register setting using the openbci 8bit v3 code.i got this code from https://github.com/OpenBCI/OpenBCI_8bit?files=1.
All things are working fine when i send the command on serial port like '+?+' its working and in return it gives me the register setting. Now i dont have RFDuino between arduino and pc and i want to use openbci_gui without using rfduino.
Now what can I do to view data to visualize the plotting. Im stuck at this point kindly help me to solve out the problem.
Regards
Laeeq
I'm collaborator with Mr Laeeq. We are having 50 Hz noise in our circuit while using 7-13 Hz BP filter & notch of 50 Hz as well, due to noise we are unable to see proper ECG signal. GUI picture is attached below, No electrodes are connected in this test. We are using our circuit on 6v battery pack.
Kindly share your expert views with us .
while keeping the electrodes open from the circuit it was giving very tiny noise of 50 Hz, but when i attached the electrode on channel 7 [(+)electrode, (-) electrode] it triggered a huge noise of 50 Hz , as you can see the uvrms are exceeding from 352 uvrms on the scale of 1000 uV.
I think when i attach electrodes to my body it then triggers huge noise of 50 Hz.
https://drive.google.com/open?id=1B6XpkLjXV9DEfpyKtpwa-teW1U-tfZBa
http://openbci3.rssing.com/browser.php?indx=58695755&item=52
