I was wondering if there was a very simple and basic way to control/manipulate any of the processing.org templates using the Cyton 8 channel and EEG headband data?
One possible way you could do this, is to use the Networking Widget in OpenBCI_GUI, to output a data stream in OSC, Open Sound Control format. The data is not actually 'sound' but the EEG waveform. Such a stream could be received by another Processing program using the OSC library.
Here is one example from the search link above, controlling a Processing program by sending OSC from a phone app. In your case you will be sending OSC that contains EEG.
You will also need to learn a bit about DSP, Digital Signal Processing. The OSC stream that you send from the GUI (and receive with Processing), can be setup to send an array of 125 float values, representing the amplitude of the EEG at each 1 Hz frequency 'bin'. See this document,
So for example, with your Processing program, you could monitor the value at 10 Hz (at array[10]), and use that to control something on the screen. 10 Hz is the alpha center frequency and increases when eyes are closed or in a meditative state.
