Having issue consuming openbci_lsl data from liblsl_matlab
mizanur36mizanur36 Dallas, TX
Running openbciPython_LSL and streaming cyton board data. Able to consume using pylsl. But when try to consume using liblsl_matlab on MAC, unable to receive any data. It waits on data in while loop
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Menlo; color: #000000; background-color: #ffffff}
p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Menlo; color: #000000; background-color: #ffffff; min-height: 15.0px}
span.s1 {font-variant-ligatures: no-common-ligatures}
Connecting to V3 at port /dev/cu.usbserial-DM00CWEQ
Serial established...
OpenBCI V3 8-16 channel
LIS3DH Device ID: 0x33
Firmware: v3.1.1
LSL Configuration:
  Stream 1:
      Type: EEG
      Channel Count: 8
      Sampling Rate: 250.0
      Channel Format: float32
      Source Id: openbci_eeg_id214
  Stream 2:
      Type: AUX
      Channel Count: 3
      Source Id: openbci_aux_id214
Electrode Location Montage:
['Fp1', 'Fp2', 'C3', 'C4', 'T5', 'T6', 'O1', 'O2']
--------------INFO---------------
Commands:
    Type "/start" to stream to LSL
    Type "/stop" to stop stream.
    Type "/exit" to disconnect the board.
Advanced command map available at http://docs.openbci.com
-------------BEGIN---------------
--> /start
Streaming data...
--> /stop
--> /start
Streaming data...
In Matlab:
>> ReceiveData
Loading the library...
Resolving an EEG stream...
When I kill the program, I get below error
In ReceiveData (line 11)
    result = lsl_resolve_byprop(lib,'type','EEG'); end
    Mizan, hi.
    Which OpenBCI Github repositories are you using? You should be using OpenBCI_Python to create the LSL stream, and then consume in Matlab with the SCCN example code,
    The OpenBCI_Matlab and OpenBCI_LSL repos are not as up to date as OpenBCI_Python for generating LSL. And even deprecated.
  • mizanur36mizanur36 Dallas, TX
    I am using openbciPython_LSL that I downloaded from github. Looks like it is generating LSL stream. I tested with pylsl "ReceveData.py" and I get the LSL data. But its when I try to consume the LSL data from matlab it doesn't get anything. Instead I get below which I mentioned.
    >> ReceiveData
    Solution from @mizanur36, posted on other thread,
    It appears the issue was the liblsl64.dylib version. I have downloaded a newer version from https://github.com/Epist/bci_focus/blob/master/Server/bin/liblsl64.dylib link and now I can see LSL stream in MATLAB
