Wifi Shield recently not connecting / with external power, GUI can't find it.
I have a wifi shield connected to a Cyton board and am using OpenBCI GUI. I have successfully had it working intermittently, but recent have not been able to connect to the software.
Here are my settings:
wifi shield firmware version 2.0.3
Open BCI GUI version 3.3.1 (MacOS)
I have configured the wifi shield to connect to my network.
I'm using the 3.7V 500MAh battery recommended for this setup.
Here is my issue. When I try to connect the wifi shield to the Open GUI software with the external power on the software doesn't find the shield (I also never get past the D2 4 blinks in 2 seconds). However, if I turn off the external power setting in the shield (and therefore turn off the Cyton board), the wifi shield will appear on the search in the Open GUI software (and blink 4 times in 2 seconds followed by 2 blinks in 2 seconds). However, because the Cyton is not turned on it won't connect to the device.
I have tried turning off external power on the wifi shield, searching for it in the software, selecting it, then turning on the external power, but I run into a time-out.
Any idea how to connect the wifi shield to the software while also having the Cyton board on?
TIA
Jeff
