Mapping Ganglion channels to EEGLAB
I am working on getting my Ultracortex Mark IV running in EEGLAB to record data.
What are the default electrode positions for the OpenBCI_Ganglion based on the standard 10-5 system https://www.ncbi.nlm.nih.gov/pubmed/11275545 and/or the 10-20, 10-10 systems?
    You can use any 10-20, etc. scalp positions that are relevant to the EEG features you are studying. The OpenBCI_GUI head map shown here, assumes Fp1, Fp2, C3, C4. But that is entirely arbitrary.
  • squadussquadus Los Angeles
    edited September 2018
    Do you know if we need to use a specific plugin in EEGLAB to configure the 10-5, 10-10, 10-20 channel positions?
    Thanks again for the help. I am following these two tutorials to configure the channel locations for use in EEGLAB and BCILAB.
    re: DIPFIT.
    With Ganglion, you only have 4 electrodes. That is not enough for source localization / dipole fitting / etc. Source localization requires a large number of channels, at least the 19 used with the 10-20 map, and sometimes more: 32, 64, etc.
    So you don't need to be concerned about exact x, y, z, coordinates. Have you followed some of the OpenBCI specific tutorials?
    I believe all you need is to correlate which EEG channel corresponds to which labeled 10-20 site. Such as, channel 1 = Fp1, etc. The 10-20 site name would then be used by EEGLAB to label graphs, tables, and such.
    I have built my .ced file and configured it using set_infer_chanlocs.
    When I run LabStreamingLayer into BCILAB I receive a warning that my cap file can not be found.
    Do you have any idea why this may be?
    A couple suggestions.
    This thread has the names of some OpenBCI users who have BCILAB experience. Try posting there, or click a username and send a private message.
    This is the support forum for EEGLAB, BCILAB, etc. You can register for that forum and post a question,
    Thank you!
    Quick question about EEG and BCI fundamentals:
    I know it is possible to pre-process, classify, and visualize real-time EEG data from OpenBCI. I want to be 100% confident, is this same function possible without LabStreamingLayer?
    When I stream LabStreamingLayer into BCILAB I am running into a warning that 0% of my channel labels match a cap design, and my srate is 0 instead of 250 Hz. The .ced file I created in EEGLAB (using this guide) has 4 channels as I have a Ganglion board with an Ultracortex Mark IV.
    In BCILAB, I have run the function set_infer_chanlocs with the .ced file, and it shows the same output.
    Do you know how to link the channel locations so the EEG data streams in LabStreaminglayer?
    "I know it is possible to pre-process, classify, and visualize real-time EEG data from OpenBCI. I want to be 100% confident, is this same function possible without LabStreamingLayer?"
    There are multiple ways to stream data from Ganglion to programs that can perform signal processing / classification of the Ganglion stream. Some examples.
    LabStreamingLayer generated from the OpenBCI_GUI (Networking Widget) or OpenBCI_Python (running on Linux) is capable of feeding various apps that can consume LSL: OpenViBE, Matlab, EEGLAB, etc.
    Python signal processing libraries can be used to signal process and graph a Ganglion stream, via OpenBCI_Python.
    Some apps, such as BrainBay, can consume the Ganglion output generated by the OpenBCI_GUI + OpenBCI_Hub. This is NOT using LSL.
    Tutorials exist on how to use Javascript to process and display the data stream from the Hub,
    I have figured out how to add the channel locations. I am at the point where now when I run the command
    run_readlsl('DataStreamQuery','type=''EEG''','MarkerQuery', '', 'ChannelOverride', {'FP1','FP2','O1','O2'}, 'srate_override', 250);
    I receive the following output (screenshot attached):
    WARNING: The value assigned to srate in set_new is not in the typical range [0.1 100000], but was: 0
    Just guessing from the comments on this page,
    Don't you want to be using 'SamplingRateOverride' instead of 'srate_override' ?
    I have tried the run_readlsl command with both variables, 'SamplingRateOverride' and 'srate_override'. inside of
    Also,
    I have tried, within the set_new() function, running this command, however, the output is still the same
    set_new('data',randn(3,100000), 'srate',200,'chanlocs',struct('labels',{'Fp1','Fp2','O1','O2'}));
    p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px 'Helvetica Neue'; color: #454545}
    I suggest you post your question on the eeglablist discussion forum, mentioned on the previous post of this thread. That is where all the EEGLAB / BCILAB experts hang out.
    Thanks again William,
    I am reading up Machine Learning now as it is kind of putting together what classifiers, modifiers, feature extraction are before I actually perform BCI
