Commands to turn on/off SRB2 and BIAS for a channel in cyton 32b
What are the commands to turn on/off SRB2 and BIAS for 32b?  I'm not using the GUI, Im getting the data accessing directly the COM port.
For 8 bits I seeit can be done with: x (CHANNEL, POWER_DOWN, GAIN_SET, INPUT_TYPE_SET, BIAS_SET, SRB2_SET, SRB1_SET) X,  (here the github with the info)
Is it the same for 32bit?
  • I tried to send the following command: 'x 1 0 6 0 1 0 0 X' to collect EMG data using Ch1N and Ch1P instead of using the reference SRB2. However, after changing it, my signal is zero (for channel 1 and all the channels). I tried changing it back to 'x 1 0 6 0 1 1 0 X' and I still get zero as signal.  How can I restart to default values?
    If I change the values in the OpenBCI GUI, do they remain changed when I close the GUI?
