networking widget in OpenBCI_GUI with WiFi Shield, UDP, fails.
abheekboseabheekbose Singapore
edited September 2018 in Wifi Shield
Hi
I have been trying the use the Networking Widget in the GUI while steaming from WiFi (at 1000Hz).
The GUI is able to stream and display data on the TimeSeries and FFT widget.
However the Networking widget under the settings below is unable to send data to my java client.
The client program is a Java program which receives UDP data on localhost and on the same port.
Settings are as follows: Networking Widget: UDP, Stream1, TimeSeries, IP: 127.0.0.1, Port: 12345, Filter: ON
I am successful with the same settings (as given above) when I use the bluetooth dongle.
When using WiFi - I received no such data
When using BT Dongle - data is received.
Is this by design or is there a bug?
Cheers
Abheek
    Abheek, hi.
    Have you tried other permutations of the settings, for example TCP or 500 Hz, etc.?
    I'm unclear of where this issue should be logged, i.e. which Github repo, GUI or Wifi, etc. Mentioning AJ @pushtheworld.
