I can't understand "spikes of noise" in my EMG signal
I attach two images that should be explicative.
In the first pisture there is the EMG signal from one channel; i didn't contract any muscle, so the "spikes" you see is all unwanted. (the signal is acquired [I suppose at 250 Hz] and then filtered with a notch filter at 50 Hz + a highpass filter at 20 Hz.)
In the second picture you can see the spectrum (fft) of the previous signal.
Can anyone help me to understand such unwanted noise/artifact? Any of you experienced the same thing? Could it be possible that my Cyton board is simply "broken" in some way?
Thank you very much in advance.
Roberto
Roberto
I connected the electrodes in the following way:
Additionally, note that I can see the muscle contraction when i contract my muscle, but the "unwanted spikes" randomly appear.
Any further suggestion?
Thanks for your support.
Roberto
Here you can see that the unwanted spikes are still present:
Roberto
I just acquired the raw data from the Cyton board without any filtering.
As you can see in the image below, there are some impulsive-like "outlier" values during the acquisition of the signal. The oscillatory behaviour I have shown before is simply due to the notch+high-pass filtering.
All the big peaks you see are unwanted, and zooming they have this shape:
Thanks, regards,
Roberto
I tried out the bias and now it seems that is working properly!
Thank you, I already red all the tutorial, but from my understanding I was thinking that for a single differential channel the ground pin was not necessary! Definitely wrong!
Thanks again for your useful help and for your time!!
Cheers,
Roberto
