Streaming from multiple (4) WiFI shields: HUB vs Python vs?
I'm looking into a possibility of streaming data from multiple (4) OpenBCI + Wifi shield boards.
I was considering using the hub, since I assume this would allow me to stream data both to my application and to the OpenBCI_GUI for inspection.
Question 1: Is it possible to stream from multiple OpenBCI boards using a single hub?
Question 2: Is the hub the "way of the future" in terms of communicating with the boards or is it reasonable to set up communication with the WiFi shield directly from within one's app? (which would prevent me from using OpenBCI_GUI in parallel with my application)
Question 3: When starting, why does the OpenBCI_GUI close any hub that might have been already running? I understand that the idea behind the hub is to have multiple applications connected to it (possibly simultaneously), and this behavior blocks such use.
dyfer
