using neuromore app with either: Wifi, OpenBCI_Hub, or Ganglion ?
Hi all,
Has anyone had any luck using Neuromore with the Wifi shield?
I can connect and stream data with the openBCI GUI using a Cyton but haven't had any luck with Neuromore recognising the device.
All the related tutorials expect the use of the bluetooth dongle and COM ports. I had a quick go at setting up virtual COM ports but didn't have much luck.
I've also tried using OSC from the GUI too but don't think it will work as Neuromore requires each OSC message to contain a only single float.
The GUI lets you transmit as a packet of 8 floats or as a float accompanied by an int representing the channel number so the messages can't be read.
Any help would be hugely appreciated.
Kind regards,
Will
Will
