OpenBCI_LSL errors with Ganglion
squadussquadus Los Angeles
edited July 2018 in Ganglion
Hello, after turning on my Ganglion board and dongle, I run the command:
python openbci_lsl.py --stream
and it outputs the following:
File "openbci_lsl.py", line 56, in
main(sys.argv[1:])
File "openbci_lsl.py", line 40, in main
lsl = streamerlsl.StreamerLSL(GUI=False)
File "C:\Program Files\MATLAB\OpenBCI_LSL\lib\streamerlsl.py", line 46, in init
self.initialize_board(autodetect=True)
File "C:\Program Files\MATLAB\OpenBCI_LSL\lib\streamerlsl.py", line 59, in initialize_board
self.board = bci.OpenBCIBoard()
File "C:\Program Files\MATLAB\OpenBCI_LSL\lib\open_bci_v3.py", line 77, in init
port = self.find_port()
File "C:\Program Files\MATLAB\OpenBCI_LSL\lib\open_bci_v3.py", line 574, in find_port
raise OSError('Cannot find OpenBCI port')
OSError: Cannot find OpenBCI port
On this page: http://docs.openbci.com/3rd%20Party%20Software/04-LSL
One of the examples is python openbci_lsl.py /dev/ttyUSB0 --stream
However, this also outputs the same error. I have tried many different variations including the ones here http://www.fieldtriptoolbox.org/development/realtime/openbci
Does anyone know how to figure out what file/root the port number is on a Windows laptop computer?  and also the syntax for including the port number on command line?
    Squadus, hi.
    The repository here,
    Only works with the Cyton board, not Ganglion. Cyton uses a serial port, Ganglion does not.
    There is an LSL widget in the OpenBCI_GUI that can output an LSL stream, from Ganglion. Can you try that?
    You can also try a forum search such as:
  • squadussquadus Los Angeles
    edited July 2018
    Thanks William,
    Are you saying that the Lab Streaming Layer only works with the Cyton board? I purchased a Ganglion board to connect to the Ultracortex Mark IV. Where is this widget for LSL on the OpenBCI documentation for Ganglion?
    On the product page it doesn't say anything about LSL compatibility.
    Has anyone else been able to connect their Ganglion board to LSL?
    http://docs.openbci.com/OpenBCI Software/01-OpenBCI_GUI#the-openbci-gui-cool-gui-features
    There is a search button and box in the right column
    The LSL widget is a feature of the GUI and can stream out to your Matlab. Thus the widget works with all OpenBCI boards.
    There are other ways to create an LSL stream from Python,
    But might require you to run Linux instead of Windows for the Python interface. See some of the forum threads, Windows hardware has lots of variability in the OS stack support for Bluetooth.
    Thank you! I will try it out.
    Can you point out where the LSL widget is inside of the OpenBCI_GUI with a screenshot?
    I have installed the latest versions of Processing, OpenBCI_GUI, and OpenBCI_Hub.
    Thanks
    edited July 2018
    [__init__() got an unexpected keyword argument 'print_enable']
    I got this error while entering `python openbci_lsl.py` to run the GUI for LSL. Here is the full error:
    Does anyone know how to help?
    edited July 2018
    Hi @squadus, I merged your new thread into this existing thread.
    Didn't you try running your Ganglion with the OpenBCI_LSL repository previously? See previous posts. This repository only works with Cyton, which uses a serial port. Ganglion does NOT use a serial port.
    You CAN use this repo below with Ganglion, but some comments indicate it may only work with Linux, not Windows,
    Alternately, as mentioned before, you can output LSL from the GUI using the Networking / LSL widget.
    Am I understanding you correctly?
    edited July 2018
    Previously, I was unable to get the LSL GUI to work. Now the LSL GUI opens when I enter "python openbci_lsl.py", although it returns __init__() got an unexpected keyword argument 'print_enable'.
    In regards to my original question on this thread, I found my port number and it is COM3.
    Now, when I output LSL from the OpenBCI_GUI using the Networking / LSL widget, both streams say they are on, however, this is no output.
    I am using the command line to verify if the OpenBCI_GUI LSL output is working.......is there another way? The above screenshot is the return I receive currently. How can I verify that the OpenBCI_GUI LSL stream is working with Ganglion?
    EDIT: I also posted this on GitHub. Maybe this belongs in the Networking thread.
    Do you have a tutorial for LSL that works with Ganglion?
    edited July 2018
    Only Cyton uses the COM port. If you have Ganglion it DOES NOT use a COM port. So I'm not sure where you are getting the "COM3" you mention. The OpenBCI_LSL Github repository is CYTON ONLY. Whereas the OpenBCI_Python repository can talk both Cyton and Ganglion. But Ganglion I believe only works with Linux not Windows.
    re: 'tutorial'. Follow the instructions in the repo.
    re: verifying OpenBCI_GUI LSL stream output to Matlab. I previously gave you a bunch of links on the other thread, which included the Matlab + Win64 binaries:
    What is it that you are trying to accomplish after you get the LSL streaming from GUI to Matlab? Are there other tools that might help, such as OpenViBE, which can also consume LSL streams from the GUI?
    Per the instructions, is there a specific package I need to run/setup?
    Maybe the OpenViBE would be easiest for you, since it comes with a Windows installer. You will still have to understand how to use their tutorials.
    edited July 2018
    Thank you for the MATLAB binaries.
    I would like clarification. I am confused as to which settings I need to configure and/or install files inside the OpenBCI_Python repo. Are there specific functions or variables I need to edit/write in order to connect my Ganglion to LSL with the new OpenBCI_Python repo ? Or would I need to move some folders?
    Btw, would a WiFi shield solve the serial connection / bluetooth error I am having?
    No. OpenBCI_LSL ONLY WORKS WITH THE CYTON SERIAL PORT.
    I see. Thank you.
    Building on your previous answer to my original post, I moved the OpenBCI_Python repo into my MATLAB folder instead of the OpenBCI_LSL folder.
    After looking at the documentation further it turns out that the Ganglion uses the MAC address to connect via ports, not the Linux operating system.
    Thanks again for your help. Have a great day.
    Yes, previous posts in the thread say the same thing: OpenBCI_Python can connect to Ganglion, but this has only been shown to work on Linux.
    "uses the MAC address to connect via ports", Yes, Ganglion access is via MAC address. Cyton access is via a COM port. "MAC address" and "ports" are two different animals.
    Appreciate the help. I have entered the MAC address into the user.py for the port number. How can I get the board to run from this point forward?
    Squadus, hi.
    You seem to have a continuing confusion with the repo you need to use. OpenBCI_LSL WILL NOT AND WILL NEVER WORK with Ganglion. Only use OpenBCI_Python repo, and it requires Linux (not Wine with Windows). Here's a tutorial that recently turned up on another thread.
    I realize this is Ganglion and OpenViBE, and you really want Ganglion and Matlab, but this would give you a start.
    Thank you William for all the help. I really appreciate you and all you do for the community.
  • Hi
    Sir, I tried the below code in python for streaming using LSL and I have a cyton board - the code is
    But it shows the same error as for @squadus mention in the start of this discussion like -
      File "openbci_lsl.py", line 56, in <module>
        main(sys.argv[1:])
      File "/home/mtp-1/pro/EEG2IMG/openbci/OpenBCI_LSL-master/lib/streamerlsl.py", line 46, in __init__
      File "/home/mtp-1/pro/EEG2IMG/openbci/OpenBCI_LSL-master/lib/streamerlsl.py", line 59, in initialize_board
      File "/home/mtp-1/pro/EEG2IMG/openbci/OpenBCI_LSL-master/lib/open_bci_v3.py", line 77, in __init__
      File "/home/mtp-1/pro/EEG2IMG/openbci/OpenBCI_LSL-master/lib/open_bci_v3.py", line 574, in find_port
    I am using Ubuntu 18.04 and python3. I downloaded the OpenBCI - Python LSL from the GitHub page and my dongle and board are switched on
    Kindly help me in this asap
    Abhi, hi.
    Use the OpenBCI_Python repo, NOT OpenBCI_LSL. Python repo is much more up to date and maintained.
