Wifi Shield non-functional after firmware flash aborted --> reflash solved it
During startup, only the LED in the wifi module is flashing.
This happens after I had a failed run to update the firmware via OTA. During the process, it returned an error message stating that "firmware erase failed"
The shield was earlier working in Direct Mode and I was getting a proper network. Now I do not see any network during SSID scans
What could be the issue?
